Old 02-10-2008, 05:40 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Default Re: Metal Grids Over Elements
Originally Posted by powdersparky View Post
Hi guys I've got a 6hx3wx3w oven with three 3000 watt elements in the bottom and a fan 6 inches from the bottom. When I bake a frame it is about 1 foot away from the elements. I would like to install some type of heat diffusing grill to minimize yellowing of clears which sometimes happens.What are you guys using and recommending as a grid and do you have any pictures to share.Would some type of convection system using the fan be better?
Thanks,Powdersparky.
convection helps but if you cure a clear too long or too hot it will still get yellow
and i know i have to restrip a frame monday a redo it
baz
http://www.polissagepb.com
