Old 02-11-2008, 08:29 AM
JTW37's Avatar
JTW37 JTW37 is offline
Caswell Platinum Member
Default Okay, New Item and idea
While my oven has been done for over a year, I just happened to notice that, at the tops/insides of my doors ( I have double doors), there is the smoke residue from the powders that smoke.
I do have a seal, but after I closed the doors and got up on a ladder to have a look ( with the lights on in the oven ), I found that I had a fairly good sized gap between the door and the seal around the center of where the doors come together. I have a home brew door latch, that apparently does not do the job.
So, When I was out browsing the local RV Salvage places for what ever I might find for my new oven, I ran across some latches, that are the draw/pull latches. I have it posted below.
Where this is going is, if anybody would like to have a couple, they cost $3.00 each and that's what you would pay me plus the S&H. These are adjustable. Oh! and by the way, it solved my gap at the top of the door.
These latches are of course made of good solid steel and are adjustable.
