Whistule,
Don't take it the wrong way, I've nothing against slang, it's considered endearing here too. But our slang is quite different than yours, understanding it is sometimes a problem. We colonials are always ignorantly assuming ours is the only. I for one, will accept "anodise" and "Fibregeek" as entirely correct spelling as well.
Back to anodising:
When putting your dimmer assembly together, keep in mind that the only thermal path for heat sinking a dimmer is through it's front panel. Use a metal cover plate on the electrical box you mount it and the receptacle in. not a plastic plate. Also for electrical safety, ground the metal cover to the green (ground wire) in the power cord. I believe you use a different color for the earth connection, but I don't know what it is.
