Re: Oven Help??
The eeee is an out of range indication I believe. If the oven was working correctly before the circuit failure, then go thru the setup procedure again for the pid and see if it doesn't start working again.
Also check to see if the correct input type thermocoupler is specified.
If you have a 35 amp draw on the oven I'm presuming you upgraded the wiring to a 50 circuit?
