  #9 (permalink)
Old 02-14-2008, 01:14 PM
fourkbmx fourkbmx is offline
fourkbmx is on a distinguished road
Default Re: What did we do wrong?
chrorides are present in tap water, you should check out you are using destilled water, i've some similar problems before becasuse i didnt used destilled water. use only tap water after the sealing
