Old 02-14-2008, 05:23 PM
JTW37's Avatar
JTW37 JTW37 is offline
Caswell Platinum Member
Default Re: Does Anyone Build Control Boxes
Curious, how big an oven you building and what wattages are your elements? If you are going to be running 5 elements on 60 amp circuit, you will need to know this. Then total all your elements and divide by 220 volts. This will give you your total amps you will be pulling.
As for the control box, there are two guys that I know of. One is on this forum, kcenicola. Look him up on the member list. Also a guy on EW, I don't know his name. Do a search over there for him or post your question there.
