Re: Chrome Cycle Exhaust Polishing
If you're careful you might be able to hit them with 1,000-grit emery paper (wet), then white compound on a spiral wheel. You might end up going thru the plating, though. Maybe try the wheel first and see what that does.
For that matter, if the rust was coming thru the plating (as opposed to being deposited from something else) it's shot anyhow.
