and will either be using one of the computer CPU heatsinks or amplifier heat sinks I have to take care of the heat.
Heat sinks won't be a problem I have them big and small, nor will be a circulation fan, or fans to put in the controller box.
Does Auberins sell all their temp controllers with a TC? Only thing that I saw was that it was configured to use a K type out of the box.
Does anyone have other recommendations for a recirculation fan? Basically I want something I can mount to the side of the wall but still be able to run the duct work inside the oven.
Since wiring a dedicated circuit for the oven in the house I'll be renting may not be possable I might try making a slide in divider plate to basically cut the size of the oven in half when doing smaller parts.
