  #11 (permalink)
Old 02-19-2008, 09:37 PM
BottleFed70 BottleFed70 is offline
BottleFed70 is on a distinguished road
Default Re: What do you think???
Originally Posted by ed_denu View Post
Here's another way of looking at the size versus wattage question. The oven you're proposing is 600 cu. ft. with 24,000 watts. This computes to 40 watts per cu. ft.
I might be making a false assumption that wattage requirements can be computed in a linear fashion based on oven size, but if other members would like to share their oven measurements and element wattage it might make for interesting comparisons.
My oven is 27 cu. ft. and has 5,200 watts, or 192 watts per cu. ft. For my needs the heat-up cycle time is acceptable at around 25-30 minutes.
I think a better way to look at this would be to evaluate wattage per square foot (surface area of the inside of the oven).
A 5x5x5 oven and a 10x10x1.25 (extreme example) oven both have 125cubic feet of internal volume, but the 5x5x5 oven would be much more efficient due to the much smaller amount of surface area.
