Re: Should I just use white compound? how fine in sandpaper should I go?
quadracer2cool4u,
When you start a new polishing project, try to match the grit of the abrasive that you are using to the metal that you are trying to polish. If the metal is smooth then just polish it! As the others stated 320-400 grit sandpaper is far enough to go then polish! It's far easier to use mechanical means to polish than to use hand labor!
John
