Re: Building my first oven!! Help me out.
If you do that, I'd alternate the studs like a sound wall with insulation in between. You'll be better off having at least 4" of insulation too rather than 2" between your studs. With no contact between the inside and outside walls, you'll get less transmitted heat to the outer wall. There's a noticeable transmission of heat at the stud contact points. A barrier wall would all but eliminate this.
