  #15 (permalink)
Old 02-22-2008, 01:40 AM
CarWiz's Avatar
CarWiz CarWiz is offline
Default Re: What do you think???
The calculators are all over the web. Google "BTU calculator" and you'll get hundreds. Some convert that to watts needed to raise the temperature to X degrees over ambient. Which is exactly what you need. You can add "heat" to the end and probably narrow-down the hits.
I looked in my Favorites but could find the one I've been using. I forgot where I put it or I'd give you the link.
