Copper plating question
Can anyone advise how an item should look once acid copper plated? im still new to plating, each time i remove the item it is coated in copper sluge which needs rinsing off,also the copper hanging wire gets a thick build up of this on it.
Is this normal,also once rinsed the plating is quite dull & requires a good buffing,does this sound normal or is something not right somewhere?
