Old 02-23-2008, 08:51 PM
JTW37's Avatar
JTW37 JTW37 is offline
Caswell Platinum Member
Default Re: Two Coat Process
The best thing I can tell you, is to make sure you have a good ground, doing the second coat. You may havve to clean a place off, that won't be seen so you can get that ground. I have done four coats. So it can be done. Keep a good ground.
