Old 10-04-2003, 03:53 AM
tbloss001 tbloss001 is offline
tbloss001
Default Re: Removing Old Chrome
Originally Posted by LITTLERED
Article(s): Chrome on Plastic Automotive Tail Light Bezels -- each about 12"L X 3"W X 2"D w/Beveled Sides.
What method is best to be used to remove the now old and cracked/peeling chrome finish in preparation for a RE-chrome effort? I hope to be able use my just received "Copy Chrome Plating Kit" to handle the refinishing process. OR must I use some other plating scheme to refinish these?
A Professional Plating Company has given a quote of $220.00 per set of two (there being two sets!)!
When you say "cracked and peeling", what is under the peeled finish?
If the original part is chromed plastic, and under the peeling chrome is a dull, painted plastic, then you can't just re-chrome it without puting a new conductive finish on the item.
I would sand the items down to the plastic with a very fine sandpaper (around #400), then paint it with a couple of coats of conductive spray paint (caswell sells some). Let the final coat dry for 48 hours and then go over it with a #1200 grit wet/dry sandpaper to have the smoothest, most polished finish you can get. Then plate it with the copy krome.
I know it sounds like a lot of work, but that's why the guy is charging $220 bucks.
