Old 02-27-2008, 04:59 AM
rogalxxx rogalxxx is offline
rogalxxx is on a distinguished road
Default What power supply?
Hi!
First of all I'd like to say hi, cos im new here.
I have a question regarding the battery charger.
I know that i need one with as much manual control as i can get. The problem is that all the chargers i found have this short circuit safety feature. I'd like to know if putting electrodes into sulphuric acid solution would short circuit the charger and shut it down? I'm not an expert but annodising is "work" and tha same thing is charging a battery, so the charger should not "feel" too much difference, right?
I'm thinking about this little fella:
http://allegro.pl/item318789098_pros...du_polski.html
i know it's in polish but basic specs are quite obvious it has a regulated current 0-15A.
or should i go with a specialized DC power supply?
http://allegro.pl/item313346302__zas...at_od_ss_.html
I know that 5A could be insufficient to anno a paintball marker body...yes, I'm going to start a garage-size anno shop mostly for paintball guns.
thank you for any comments
