Re: Disolved Al in Ano tank and Ano thickness?
Destroyer125,
Guess I should have explained better. When I use 1mil, 6ASF it goes to 15v, but, just to experiment I did 8ASF (90min) to cut time and see if time in tank was getting disolution and then my power supply showed right around 20 volts.
Isn't 12ASf outside of LCD specs? or am I reading that wrong or not understanding correctly?
The 55volt/10amp is the max my power supply will do. I still set/turn voltage knob all the way up and then set the current/amps knob at whatever the 720 calculaor says for part being done and let it run.
=72 square inches = .5 square foot at 1 mil = 6 ASF = 3 amps for 120 minutes with peak voltage of 15v. which my power supply normally shows voltage around 14-16 volts and hold amps at 3.
Reason: spelling
