Originally Posted by parad1mg
i recently scored a good deal on some Mickey Thompson Classic II Wheels with tires on them.. they are aluminum wheels WITHOUT any coating on them whatsoever.. ( link: http://www.mickeythompsontires.com/w...item=ClassicII ) unfortunately the wheels were not maintained and were exposed and used in winter conditions, so it had road grime, crusty brake dust, road salt, gunk, etc..
i tried everything just to remove all that hard dirt stuck on the wheels.. the only thing that successfully removed it was WD40 and 0000 steel wool.. now i'm left with a smooth finish but it has pits and white spots on it!!! i cannot remove them for the love of god with any off the shelf aluminum polish.. i already tried mother's products, eagle one products and whatever i could find at the local auto parts store..
i havent finished cleaning it off 'cuz i got so frustrated on why those spots wouldnt go away.. so, pleeeeaaasseee? somebody guide me to the right way?
i only have a dremel tool, a VSR drill, my aching arms and a wallet that's exhausted from buying products that do not work.. i just want to make it look like new again, almost like chrome, and possibly my face on the reflection.. lol..
If you're sure there's absolutely no coating on it (including anodizing), all I can tell you is it's time to start sanding if you want mirrror-finished wheels. Try an small area, start with 500 or 600-grit - get the kind they sell at auto supply stores and try it wet. Use a rubber block with sandpaper. If you have power tools there are ways to use them, too.
If 500/600 doesn't get off all the spots, try 320; if that doesn't work, go down to 220 (that's probably low enough), then come back up thru the grits, then you can polish with a drill and buffing wheels. There's plenty of info in here, just do a search on actual procedures.
