  #9 (permalink)
Old 03-02-2008, 10:10 AM
jrow jrow is offline
Default Re: how to get ride of a cloudy finish
Originally Posted by snoop View Post
i can not thank u enough mpierich. thank u very much for your input and sharing some of your experiences. love this forum, and i hope i get better and better at this polishing thing. thank u again. i will use your method on my frame
p.s., what i just did was use a polish that i had sitting here. almost a rubbing compound, but very mild i used for polishing, and that seemed to get ALOT of **** off that i thought i got off using my laquer thinner(guess i was wrong). i mean the rag was black even after the laquer. so any other newer guys reading this, using a polish or something with a mild mild mild grit, works great also with getting rid of that cloudy ****.
Snoop,
I noticed that you are using lacquer thinner to clean your part prior to changing compounds. Try using acetone to clean when changing compounds. Use a different buff for each compound. For a final clean up prior to using Mothers Mag wheel polish, that mpierich suggested, use some Dawn dish washing liquid in warm water.
John
