Re: home built oven
396( 375HP?) Going to need a little more info, Are L1 and L2 both 120 off the same source, or is one of the terminals a neutral? (It appears that this is the case). Most likely the terminals 1,2,3,and 4 are two hots and two neutrals, but this info needs to be checked out. With this info supplied and and the elements sized to 240 volts, it should be easy to make a change to 240volt, after some mods. to the wiring. Fred
