I've been doing LOTS of reading and all I can say is
Wow! I love the new LCD anodizing instructions. Excellent documentation! Those are the kind of answers I've been looking for. Did you write that documentation, FiberGeek? The instructions sound a lot like your writing.
Anyway, I've been planning an upgrade to my existing system, and the new LCD system looks like a good way to go. The only problem is this. I bought all of the components necessary to build 2 large, unregulated, 12V power supplies (Transformers, bridge rectifiers, LARGE capacitors...) I have everything needed for the "old" method. I plan on simply adding another anodizing kit, and keeping the old one in service while I ensure that I can get quality results with the new kit. (I've seen how touchy anodizing can be to changes... Just covering my butt.
I see in the LCD instructions that the author built a VCCS (Voltage Controlled Current Source). How difficult is this? From the picture, it appears pretty simple, using a rheostat, an IC, some resistors, and possibly other stuff. Does anyone have any good instructions or good links for making a current source? I just don't really want to pay the $300+ for a rectifier when I have all the materials for 2 large PSes. If it's possible to add some control circuits to a PS to make it a current source, I'm all ears.
I noticed that with higher current densities, peak voltage can top 20V, so I'm assuming I should wire these 12V transformers in series to make a 24V PS. Any other tips?
