Thread: polishing frame
Old 03-05-2008, 11:09 AM
mpierich mpierich is offline
Default Re: polishing frame
If you use emery you can probably stop sanding after 600.
At this point I would try the emery again and see if that takes out the scratches. And if you do each step in a different direction (not always possible), you should be able to tell which one is leaving the scratches.
BTW, tripoli is usually brown in color. Red in most cases is a fine rouge that you'd use after white.
