Thread: polishing frame
Old 03-06-2008, 11:46 AM
jrow jrow is offline
Default Re: polishing frame
dewie,
The finer grit sand paper you use the less work you have to do before you can start polishing. The object of sanding at a different angle is to sand out the scratches that you made from the previous grit! At times the deeper you sand the more "pits" you're going to run into.
Your progression of polish and wheels is correct.
In the thread that you read you probably read about "greaseless", that may be something you'll want to consider if you stay at the polishing game.
John
