Re: polishing frame
Remember, the reason to cross-sand is not only that it will work faster, but it will allow you to see the previous scratches. Use a strong lamp and look from differet angles. I've found that actually SEEING what you're looking at is an acquired skill, and just as important as the actual polishing.
