Old 03-07-2008, 12:30 AM
acidrain acidrain is offline
Default Re: Does PC power supply work?
Originally Posted by jayu View Post
Hi, totally new to anodizing (I have done a little bit of reading though). I basically wanna do this on paintball guns only. Since I have a couple of them I thought I should just do this myself to save on money. Thanks in advance for answering.
I read somewhere that you can use a computer power supply (atx). Is this true? I have an extra PC power supply Im hoping to use... 19a @ 12v.
Also, when computing for surface area, do you take the inside into consideration? Thanks!
For consistant results, you really need a constant current power source capable of holding steady current in the 15v range.
For a small batch of PB parts, 10 amps will be fine, but for larger batches (more than just a body, gripframe and reg) you'll want a 20 amp PS.
Yes, you include all surfaces when calculating SA.
