Re: WeTDrEaM Oven Build. Step by Step
Since the upright stud is the larger (smooth stud with no wiring holes) one I had to notch it so that it would fit into the bottom stud of the same size. I cut a scrap so you guys could see how I made it fit. It was then screwed into the upper and lower framing. I left the little piece pulled up so that you could see how I did it. Those parts were cut of before installation.
