  #19 (permalink)
Old 03-09-2008, 04:00 AM
wetdream wetdream is offline
wetdream is on a distinguished road
Default Re: WeTDrEaM Oven Build. Step by Step
Here are a few pics of the unfinished door also. Ran out of self tappers!! The lower center square will be where the window is going. I will also be framing below that just like the very top. I decided to add a little more support to it since it is so big. I will also be adding steel stock to the sides where the hinge and latches will attach just like the track. Drilled and tapped so it can be bolted together without worry of the bolts pulling out of the thin studs and sheet metal.
wetdream-oven-build-step-step-powder-coating-oven-019.jpg   wetdream-oven-build-step-step-powder-coating-oven-020.jpg
