Originally Posted by spills
I might not need both elements, but I figured a little overkill couldnt be bad. Here's a quick MS Paint showing what I was thinking about doing. Let me know what you think, and what you think I should do as far as enclosing the elec. connections at the element (junction block, something like?)
I would not leave 240vac wiring exposed, outside the oven. If you find you need to have a second element, I would look for a better way of mounting it elsewhere than the door.
