Originally Posted by GatorHyde
Fan install. First I think I will say that if I was building another oven I would frame 1st, sheet the inside, element/fan/light install, wire, then insulate. Live and learn. With that said, I removed the back sheet metal and insulation to install the fan. Measured, and centered, cut the 5" hole, ground it as "round" as possible and drilled the fan mounting bolt holes. Before permantly installing it I am going to put a bead of RTV high temp seal around the round hole where the fan meets the sheetmetal.
Are u using the fan as an exhaust or to circulate the hot air?? Or Both??
Just trying to understand thats all.
