  #9 (permalink)
Old 03-14-2008, 08:05 AM
JTW37's Avatar
JTW37 JTW37 is offline
Caswell Platinum Member
Default Re: A thought about fans...
Originally Posted by CarWiz View Post
Calculate the volume of your oven. Moving that volume once per minute is more than enough. Half that would be better. WxDxH/2= CFM for the fan. (or nearest rating.) If you go too high, it will also diminish the effectiveness of your heating coils and raise heat-up times. In this case, more is not better. Also, any dust in your oven will be spread over your parts during curing if the fan is blowing too high a volume.
On that statement, my figures out to be 27 CFM. So I should be using that or half of that. So if I had double of that CFM, I'm defeating the purpose of the whole heating thing, correct? So would you say 12 to 15 CFM is better then 27?
