Old 03-14-2008, 04:28 PM
mpierich mpierich is offline
Default Re: Best Method for Emblems
Originally Posted by jaeger6 View Post
I think I could come up with a holding fixture.
Grinder's Grease? Is that like Du-all's stick wax?
I believe it's animal fat. If you use the high speed grease for a belt sander it'll gum up your belts. It has a higher melting point. Low speed has a low melting point. I believe Caswell has both. Don't use too much. And use a belt cleaner frequently.
