Old 03-17-2008, 12:45 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Default Re: question on another motor/flex shaft
Originally Posted by mpierich View Post
Number 2 is just a glorified Dremel - you'd burn up the motor and that little shaft would twist up like a pretzel if you tried to use a 4-6" wheel.
Number three looks OK, except they don't tell the length (and it looks short to me). By the way, you'll notice the wheel isn't spinning in that pictue. You can't bend the shaft that much and have it last very long!
what am i missing here ?
i have only 2 links one for #1 that is like you say a glorified dremel with a skinny flex shaft , wich i would never use with anything close to a 6 inch wheel
then the second link for # 2 wich looks much bigger but like you say they don t say anything about the lenght of it
baz
http://www.polissagepb.com
