Re: Cadinum and Zinc Plating help - Anode turned grey?
hoopie, may try this for starters, it sorta happened to me also,make sure your copper 1/2 tube is clean and shinny and is your brackets hitting the anodes??
Also make sure you electroplate is around 95 to 100 degree,s. Should be ok i think.
P.s./ funny, but the way my circulation pump is postioned sometimes makes a huge differance also.
