Old 03-17-2008, 10:15 PM
Dels383TA's Avatar
Dels383TA Dels383TA is offline
Dels383TA is on a distinguished road
Default Re: Little Compressor
Originally Posted by jeremy0203 View Post
i have a 26 gal, 1.5 hp 155 max psi AC, would this be ok for media blasting or do i need to go even larger
Pretty sure that you will kill you compressor fast if you try to blast with it if you are using anything more than a small hand held blaster.I have a 60 gal that when used on my blast cabinet will run often.
