I wasnt around when they did it .....but im sure they used the same process they always use.....i know they soaked everything in some kind of degreaser ...or other chemical......and i told them that the manufacturers specs ...say to cure it @450 degrees for 20 minutes.....they did go right over the orignal chrome....but that shouldnt have been a problem. right now im thinking that they probably didnt let the metal reach 450.....before they started counting the 20 minutes....if thats not it ..then i have no idea.....the Coating wasnt too thick ...or thin......So
? ......the next time they try....everything will be bare metal....So if they let it cure longer....will that keep it from coming off? ........And Yes the parts are pretty new ....off a 2007 roadglide.....i bought it new last fall.....im trying to black out as much as i can.....like the exhaust (mufflers) ..and heat shields ....the crash bar....air cleaner cover ..etc. .....its going to look awesome! ....if i can get the powder coating right! ..... Any tips or suggestions that might help ....would be awesome!!! if i ever get it right... i`ll post some pics ..... Thanks
