Old 03-19-2008, 09:51 PM
ed_denu ed_denu is offline
ed_denu is on a distinguished road
Default Re: PID with Ramp/Soak/Kiln?
Ramp/soak would probably be more useful if you are doing a lot of large heavy parts that take time to come up to temperature or if you are doing a lot of production/repetitive type coatings. I think it would be less useful for a job shop.
I don't depend on the oven pid temperature readings. Instead I use an ir thermometer to read the temperatures of the parts and start the cure cycle from that point.
Most of the alarm features are only low and high temperature alarms. I changed my oven controls to include a countdown timer that shuts off the elements at the end of the cycle and sounds an alarm.
