  #10 (permalink)
Old 03-20-2008, 09:29 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Default Re: High temp Powder coating Problems
Originally Posted by smackgod View Post
Has any one had any luck with the high temp powder coating from Caswell? ......i brought in 23 parts off my new harley...to work .....were they powder coat all the time......and basically the coating came off in sheets...and the stuff that stuck....looked like ****! ....... the only thing i can think of is ..they didnt let it cure in the oven long enough? ......I read someones blog that said even silicone residue from the air compressor can cause it to not stick? ......which is really confusing to me.....since the High temp is supposed to be silicone based? .......Any help or suggestions would really help!!! .... i really dont have $3000 to replace the parts ..if the screw em up again !! Thanks
there s a part of your question i don t understand .can you explain that part
i have done a few parts with caswell s high temp black no problems .
like harley dad i would use high temp only where needed
were the parts all stipped to metal and prepped before coating
i know that if you try to do double coat with high temp you might have the top coat peeling off
baz
http://www.polissagepb.com
