Originally Posted by Fox
From what i understand welding galvanized will bring out toxic fumes so you might be better using sealant instead.
A true statement about the Galvanize. You don't want to breath that stuff. Don't weld it, you won't be able to get to anything, if you need to. The sealant that I use is working fine and has caused no problems thus far. I intend on using it in the oven I'm now building and the next one I have in mind.
