Seems to me you have a grounding problem. Ground your parts directly and try. Are you using tribo or el.stat gun ?
Did you know that it is possible to use every gram of powder if you recycle when coating, and vapors are almost none !
In a wet paint approx. 80-90 % evaporates into the air. Causing stress on the enviroment !
1 kg. of powder can cover approx. 10-12 m3
1 litre. of wet paint covers approx. 2-3 m3
