Old 03-26-2008, 05:06 AM
jungles82 jungles82 is offline
jungles82 is on a distinguished road
Default Help with small parts
Ive been polishing for a couple of moths now my hands are sore from sanding and my finishes look like **** i start with 180 and go to 3000 grit then i use the black tripoli then brown then white on a loose sewn wheel im doing atv parts none of them have turned out perfect the biggest problem is the small areas i go trough the felt bobs like tiolet paper and leave swirl marks that i cant get out my recent part are off an 87 honda 250r the water pump cover has so many small pocket and other areas that i cant get into even with the small dremel felt bobs should i just throw it in a tumbler and pray for the best or what im frustated i have already polished parts and i cant even make them look good can anyone give me advice on what to do? I really need the help thanks matt a lost but found agian member the hole reason i started this was a 700 dollar bill to have a guy do a half a$$ job on some of my parts but his still look better. If i cant figure it out im gonna invest in the powdercoating stuff and just cheat its nice low maintenence and easy to clean.
