Re: wiring schematics anyone?
The number of elements you use will be determined by the electrical service that you have. 100 or 200 amp service. If you will be running it on a 50,60 0r 100 amp breaker will be the final deciding point. Total all wattages and divide by your service voltage ie., 220 -240. That will give you total amps draw.
As for wiring schematics, there are several. Which type of controller will you be using? An SSR or the older Contact points Contactor? I have a diagram of mine, which is the Points Contactor. You would need to do a search in this forum for the SSR type.
Photo's won't upload if they are to big. Try it again, we would like to see your build.
