Re: engraved firearm electroless nickel
I haven't worked with electroless plating, but from my experiences, the engraving will look the same after as before. For example, even a wire brushed part shows the marks after plating. Usually even fine lined engraving is deeper than that. Can you catch your fingernail on the engraved part? If so, I don't think you need to worry, unless to plan on building an extremely thick layer.
