Old 10-13-2003, 11:21 AM
non-stick non-stick is offline
non-stick
Bryan.....
As far as "driver-woods" go, no. I can't say that I've actually coated them. Titanium and the like? You bet....almost to the point where I'd kill for a nice piece of cast aluminum. Point is...it's very easy stuff to coat. Same with stainless under the correct circumstances (which shouldn't be a problem in this temperature range). Media blast with a high-abrasive grit for adhesion and you'll be good to go. As for removing the heads...I most certainly would. Is it a bear to do this process? More than likely. If it were me personally? I's take the time and sperate the two from thier marriage and coat the shafts independantly with powder. Tons more durable say then...a lacquer,or other liquid coating that's on them now? Not to mention...the struggle that you'll go through now will be worth it in the long run for durability sake. Use a nice poly coating on them and you'll do just fine. Hope that helps.....Russ
