Re: Moisture Problems???
Check your ground. make sure it is on a clean place of the item or hook. It has to be good or the powder won't stick. Also hold the end of your gun toward the part and press the pedal, don't pull the trigger and see if you get a blue arch. If you do, then the powder should stick. If you decide not to get a EW Pro Gun, then do the mods to yours, it helps. Also, There's been a lot of complaining about the Pro gun, but also some good comments. I decided to wait a bit and see what goes with the complaints.
