Re: engraved firearm electroless nickel
Since I have your attention, what about areas you do not want to plate? like the inside of the bore? I assume you do not coat with oil or something as you do not want to contaminate the plating solution during the plating process. not to mention using plating concentrate on areas that do not require it, so how is the best way to exclude conecting parts from the plate job. hope I made sense of this. thanks Al
