Re: Help with small parts
well i dont know if im using the same stuff as you but mine looks like a big black brick and smells like a crayon is that the right because this stuff on a spiral sewn wheel it wont take out scratches from 400 or even 600 it will take out 1000 grit scratches with a little work but it turns out way better if i use 1500 but like ive said ive tried to just use the 400 but it looks crappy so thats why i go to 1500 do you have any suggestions on what i should change?
its alot of damn work to be shinny
