Old 04-03-2008, 06:18 PM
sross sross is offline
sross
Default Re: Advice wanted on rusty pits
Originally Posted by carts69 View Post
Can anyone advise on the best method of removing rust from pits, when i use my usual method of pickel #3 for stripping old nickel it leaves the rust in the pits. What im looking for is a 100% clean base metal, can anyone confirm if sand blasting is the best method or is their a better method to clean these tiny little fellas?
No, I would not blast it. The main warning in plating guns is to NOT blast while the blueing (which is rust) or rust remains. Blasting can actually drive the rust into the base metal later causing rusting under the nickel.
The best thing to do is use the rust remover, clean in household ammonia, then blast the surface to clean the remover residue. Dipping in hydrochloric (activator) before plating also removes any invisible new rust film.
