Old 04-03-2008, 06:41 PM
amerdunbar's Avatar
amerdunbar amerdunbar is offline
amerdunbar is on a distinguished road
Default Re: Safe Materials for Indefinite Immersion in Nickel Plating Tank?
I really can't see contamination being a concern, unless the bath got hot enough to completely melt the glue, (my SP degrease tank has). Since nickel runs at 110F, the biggest problem would probably be the glue letting go of the plastic bucket, and your air tubes coming up. I've seen some pics of small tanks that had holes drilled in the sides near the top to hold rigid plastic tubing down. Probably the most ideal setup.
I'd like to see a definitive answer too - since it would be nice to be able to just use something to weigh it down.
