Thread: flat aluminum
Old 10-15-2003, 08:33 AM
breeze breeze is offline
breeze
Make sure you are "crossing your lines" each time you drop down to a finer grit/buff. Also make sure before you do this, that all the lines are coming out. Crossing your lines will make it easier to see what you didn't get out at the last step. If the lines are too heavy, go back to a grease belt. Remember, aluminum is very soft and it doesn't take much to put lines back in even when buffing.
Breeze
