Old 04-06-2008, 10:25 PM
acidrain acidrain is offline
Default Re: degreaser question
The wispy areas are probably trapped acid. Are they near screw holes? Take care to squirt rinse water into all the nooks and screw holes after pulling from the ano tank.
Surface contamination doesn't usually do that. I'll bet your degreaser is fine.
As for the white slurry, mine does that as it get's cold, then disappears when heated, so I think it's normal.
If you can avoid touching the parts after ano (even with gloved hands) so much the safer. I usually keep the racking wires attached and just handle them that way until after sealing.
